Продукция
Старые программы
Помощь VSO
Волонтерские переводы
Тестирование бета-версий
Бизнес с VSO
Для реселлеров
Для партнеров
B2B услуги
О нас
Техподдержка
Продукция
Помощь VSO
Бизнес с VSO
О нас
Техподдержка
< Назад
Вся продукция
Старые программы
< Назад
< Назад
Для реселлеров
Для партнеров
B2B услуги
< Назад
Jump to guide's index
PDF version v6
PDF version v5
I -
Insert your files
into software (drag and drop or use the green cross button to browse your file(s).)
b) Optional
: if you click on the titleset, the preview window will show on the right: you can check the video by clicking on the "play" icon in the middle of the screen. The tabs under this preview lead to most available editing options. More about these options below under 'Overview of editing function in tabs'
II -
Insert a blank DVD
if you wish to burn your conversion straight to DVD
III -
Press "Convert
You're all set!
Index of Complete guide
Basics
Basic Conversion
Main menu
Default Settings
Menu Editor
Create & save a new menu
Menu editing (Version 5)
Editing tabs under the preview window
Preview
Audio streams
Subtitle streams
Chapters
Image settings
Output
Cut
Merge or join files
*Any changes made here will affect the titleset selected in the treeview, showing in the preview window.
If you want change settings that will apply to all your titlesets and/or all your future conversions in ConvertXtoDVD you should make these in the
Default Settings
, in the top menu of ConvertXtoDVD.
Other quick links
Batch conversion
Burn another copy
Add or edit subtitles
Convert PAL to NTSC or vis versa
How to remove commercials or other unwanted sections of a video
