Продукция
Старые программы
Помощь VSO
Волонтерские переводы
Тестирование бета-версий
Бизнес с VSO
Для реселлеров
Для партнеров
B2B услуги
О нас
Техподдержка
Продукция
Помощь VSO
Бизнес с VSO
О нас
Техподдержка
< Назад
Вся продукция
Старые программы
< Назад
< Назад
Для реселлеров
Для партнеров
B2B услуги
< Назад
VSO Downloader 6
FAQ
Detection issues
No streaming is being detected / one stream is missing
- Can you detect our test video? In VSO Downloader, go to Help menu > Online help > Detect my first video now. If you can't detect it, it may be due to a network problem, please contact the
support.
Here are tutorials to delete the cache. Click on the one related to your browser:
Firefox
Chrome
Internet Explorer
- The media is encrypted through HTTPS. In this case, VSO Downloader does detect an HTTPS content but can't download it. It will be downloadable in a future update. Meanwhile, you may bypass the problem by
using a screen recorder
No video is being detected on YouTube
See here for details
Understanding download errors
I am getting 'error' or 'downloaded with errors' status
- Socket Timeout
- Part size not complete
What does 'Protocol not supported' mean?
It means VSO Downloader can't handle the download of the media file. It is possible it will be supported in a future version but we do not know how soon. You can use a screen recorder as a temporary solution, see here for a
here for a short list
Miscellaneous
Why some of the files are in queue?
Why does it download duplicate files?
1 -
The video restarts at the previous position so it is considering as a new video and will be downloaded again
2 -
The video restarts from the beginning, in this case it should not be downloaded
Why is there a '(2)' or higher next to the file name?
What is 'live recording'?
What are the supported sites?
How can I play downloaded files?
We recommend using our own and free VSO Media Player.
Download it here
What do I need to run VSO Downloader?
Do I need to be administrator in order to execute the program?
Does it support the loopback device?
